No floor drain for softener
Tyler Padgitt
Hey guys I just got a Marlo water softener. I have no floor drain for it and send the discharge overhead. What should I do for the brine tank overflow line? Stick it in a 5 gallon bucket?
Most systems use a timed refill and include a safety float in the brine tank for proper redundancy to prevent water from overfilling the brine tank due to a power failure during refill, or a leaking and worn brine valve.
The gravity overflow is rarely connected unless the system is installed in a highly water sensitive area.
Softeners should not typically be installed in highly water sensitive areas without proper floor drainage in case of a leak.
Can anyone confirm that a Marlo Water Softener has a Fleck head? I was told it does.. Or at least that Fleck makes the heads they use?
