I have a basement
where I am putting in two toilets. I need to have an ejector pump as well.
Due to the position of the toilets and support beams, The line where the second toilet meets the first line is heading in the opposite direction of the flow from the toilet. Will this cause issue?
See attached image.
where I am putting in two toilets. I need to have an ejector pump as well.Due to the position of the toilets and support beams, The line where the second toilet meets the first line is heading in the opposite direction of the flow from the toilet. Will this cause issue?
See attached image.
