Cacher_Chick
Test, Don't Guess!
All tanks leak sooner or later. If a leak would be a disaster the heater should be sitting in a properly installed drainage pan.
One thing I'd consider in your situation is a WAG valve...you must have either a pan underneath the heater, or be able to add a dam around it. The valve gets plumbed into the supply water, and if a gas unit, the gas control. If the water level rises to about 1/2" in the pan because of a leak, the valve shuts the WH inlet water supply off and disables the gas valve. You could use that switch to trigger an alarm, if you wanted, instead. If installed by a trained installer, they also give you a free property damage insurance plan. It should be enough if the pan is plumbed properly to a working drain. http://www.taco-hvac.com/products.html?current_category=65
Question about the WAG: Is this a one-use device? In other words, is the dissolveable fiber element replaceable or do you have to replace the whole device?
Think of it as an airbag...I'm pretty sure it's a one-time use thing. Once the spring and seat get wet, I don't think they could guarantee it to work again if it was rebuilt...maybe, I'm not sure. You can retrofit a dam around the existing WH, but that only works on a slab. Otherwise, you need a pan whose outlet will allow enough water to pool before it drains to trigger the thing (about 1/2"). It uses the same thing as the emergency floatation vests in airplanes...they sit around (hopefully) unused for years before needed...when it hits the water, it opens the valve to the CO2 cartridge to inflate the thing once it (quickly) dissolves the pellet that normally stops the trigger mechanism.
Got it, thanks. And I thought you had to blow into the vests on the airplanes to inflate them. Isn't that what they show you on the safety video?
