Water softener resin is green
earlrabbit
Salt Lake City
I've been having problems with my 14 year old Northstar softener. I suspected that the resin might be bad as I've never run anything like "Iron Out" through it. After opening it up I see that most of the resin has an amber color but some has turned green. I don't see anything that looks like iron contamination. Is the resin bad? I've been inside the valve many times so I'm very familiar with it but is it time to bite the bullet and buy a new one?
Take a few beads and crush them between your thumb and forefinger. If they crush they are bad. Try it with both the amber and green beads. I suspect that either the resin is failing, the resin is channeled or the bed is not being properly back washed
Can you post a picture? Green might be an indicator of copper fouling. Considering the age and make, it might be a good time to start looking for a replacement system.
Not sure on pH, but hardness is 13.85 grains/gal and iron is .03 mill/ltr. It's city water but they source part of their needs from wells.
