I am about to start rewiring the lighting in my kitchen. Right now I've got four lights on one circuit controlled by two separate single pole switches (two sets of two lights, each with a separate switch). Currently it's set up with 12/2 wire to the first fixture with the switches at the end of the run. What I'd like to do is add a third set of lights so the setup would be as follows:
Light Number one: One Fixture, One dimmer switch (easy enough)..
Light Number two: Two lights and a 3-way dimmer
Light Number three: Three lights and another 3-way dimmer.
I'd like to keep the power feed from the panel at the first light and distribute everything from there if possible. Otherwise, I'll have to tear out the whole ceiling. Please see the link below for the diagram. I would really appreciate any suggestions.
http://share.shutterfly.com/action/welcome?sid=0CbuXLlq4aNnHQ
