I can't talk my licensed plumber into replacing my 2003 FERGUSON water heater. He swears I'd be wasting money. He keeps telling me to bypass the thermofuse by putting a jumper between the two wires, but I keep refusing. But honestly, I'd really like to know what this switch does. Several people here keep saying things like "having blown up your entire neighborhood". Every other brand of water heater doesn't have this switch. If you have the gas shut off safety and a pop-off valve for pressure - like all the other water heaters - then why is this switch there and why don't the other water heaters have it?
And here's my brief experience. While mine has lasted almost 10 years, I had all the same problems within 3 years of installing it. I used the reset button and got it lit the first couple times. Now we deal with the heater set to warm - which sucks. It's the only way to keep the switch from tripping.
FVIR was designed after a lady allowed her 4 year old son to play in the garage and he found a gas can and poured it on the floor. The ensuing fire resulted in his death, and she tirelessly campaigned Congress until a solution? was found in the form of FVIR.
The way it is supposed to work is by the fact that a flame will not travel through a fine screen. You will see this screen on the expensive "safety gas cans" that have been made for decades. It is a well known principal.
When the flammable vapors are drawn up through the screen and ignite in the combustion chamber of the water heater, there is no way for the flame to travel back out to the source of the vapors. The heat of the burning vapors will trip the thermal switch or fuse and shut down the water heater. It does this by interupting the 30 millivolt signal from the thermocouple (simulating a pilot failure) and shutting down the gas valve. There is nothing special about the valve or thermocouple, except for the left hand thread used for a short time by Whirlpool.
A clogged screen will cause insufficient oxygen, and an oxygen starved flame will produce carbon monoxide which will mostly go up the flue. The starved flame will also produce a lot of soot which will stick to the metal surfaces in the heat exchanger tube, causing poor heat transfer and wasted utilities. This is in addition to the gas which is wasted because it can't be completely burned without excess oxygen in the combustion chamber. Even after correcting the cause, the soot will remain until physically removed.
A clogged screen will cause poor drafting and the combustion chamber will get excessively hot, this will cause the thermal limit will trip before the heat exchanger tube is fouled with soot, if you're lucky.
Whirlpool doesn't care. When they purchased Maytag in 2007 for 1.8 Billion dollars, they immediately fired all 7,000 USA employees and moved the factories overseas. They also raided the pension funds for those workers.
