Robert May
Should I supply hard water or soft water for the icemaker on my new refrigerator. Both are available with about the same difficulty.
I am quite sure you do not want to ingest soft water.
Just how much sodium do you expect to get from ice cubes to make it a concern?The only reason for not ingesting soft water would be if you are on a low sodium diet.
True. It is softer. RO filtration can affect the pH and also being the "universal solvent" that it is, can be "aggressive" in dissolving some metals such as copper.RO water is NOT the same as "soft water".
Hard water will give you cloudy cubes because of the suspended minerals in it.
Why not? I use only RO filtered "soft" water for ingesting.
I use my RO to feed my icemaker also. When he said "soft water" I assumed he meant a salt water unit.
Longtime lurker, first time poster. Slight hijack, please.
Whole house remodel, ran copper for an icemaker, figuring it would come off a RO filter under sink. Heard a few theories about compatibility of RO water and copper, wondering what the collective wisdom of this board is. Copper is buried in wall.
TIA, Todd
