Sam Downing
I just replaced my 1/2hp jet pump with a1/2hp new pump, and the expansion/pressure tank (25gal) with similar size. I am drawing water, but only enough to run a single faucet and not enough to reach the second floor or power the first floor shower. The switch is set 20-40 as factory settings and the pressure tank is 25lbs. To increase my pressure is it simply increasing the switch settings to 40/60? That's where the trigger points were on the previous pump. My gauge is currently reading 25lbs.
Thanks for your help
Sam
Sam
