Autotrol Performa Valve with a 460i control
jacktorgerson
Phoenix, AZ
I have an Autotrol Performa Valve with a 460i control. It has stopped auto regeneration. I can manually regenerate. Any idea where the problem is?
Is there a little light flashing when water is used in the house?
Could be that either the meter cable at the turbine is out of the hole or the turbine is not spinning.
Make sure that the light is flashing when water is running.
Thanks,
I checked for the flashing light when water is running in the house and it does flash when water is running.
I checked for the flashing light when water is running in the house and it does flash when water is running. Are there any other things to try?
