Dittohead, he was talking about the BLFC not the DLFC. The BLFC is located in the brass piece that the brine tube connects to. You would have to remocve the brass piece and inside is a white plastic holder. Use needle nose pliers to remove the plastic holder to get to the BLFC. I would not do thid because most of the time the plastic hloder is torn up trying to remove it and if you don't have a replacement, you can not put it back together. you can use a measuring cup and time it. .5 BLFC = 2 cup in 15 sec
