You know, it's threads like these that I wish amateurs would refrain from commenting on unless you know exactly what you're talking about.
Not sure what that is about?
I was under impression that at this forum, "amateur" like me can get advise from "pro" like you.
It appears that this it is my setup. 2" pipe which has 1" pipe inside. I am sure that I didn't brake that 1" pipe trying to pull it out. I was gentle with it. Jus little wiggle and gentle pull. It didn't separated, so I stopped.
However, after assembling everything together pressure dropped from 30PSI to 20PSI. For some reason within few hours it drops almost to zero. Is it possible that water is going back to well? I didn't try to shot main valve and observe if pressure will drop again. Project for tonight
I called another "well-man", and he confirmed (after checking the flow from running pump) that most likely my packer jet is at fault.
He will replace all guts at the bottom of the well (packer jet, screen and foot valve) for $1400, but without any guarantee, which I understand. He said interesting thing, though. I changed pump from 1/2 HP to 3/4 HP, and according to him, that was wrong move, since packer jet installed in the line was "matched" with the old pump.
I know, I am taking my chances with replacing parts instead install whole new well, but isn't whole life a gamble.
I'll let you know how it turned after Tuesday.
I am about 30 miles NW from Detroit, we do have plenty lakes around here so I am thinking that that lack of water is the least of my problems. Since I purchased brand new tank and 3/4 hp Myers pump I decided to go with replacing the rest of the "gizmos" .
LLigetfa, valveman , Texas Wellman, thank you for your comments and advise, definitely I, and hopefully everyone reading this thread learned something.
It is late night already, and who need water, time for "better liquid"
Cheers.
