I agree, but if you can find an attractive fireplace hood/canopy, it can deflect the heat enough to "spill over" up far enough away from the TV (maybe). Personally, I would not do it, as flat panel large screen TVs are still rather expensive even with the prices having dropped. Nice look though.My experience has been that they do NOT recommend mounting a TV over a fireplace, unless it will NEVER be used for a fire of any kind.
First off, you have a load of questions and before you race off building your next project you need to hit the brakes and do some homework.
It appears to me that the stand offs to your fireplace have been removed or they are just so tiny I can not see them. Can you upload more pictures of the fireplace and the exact make and model. I'm looking for V Shaped pieces on the top, back and side of your fireplace. This make and model information will be on the lighter tag under the fireplace near the pilot lighter. Is that unit burning gas even? Might be an A vent or wood burning. ???
Once we have that we can then answer the drywall question. The insulation question and the rest.
I have been building fireplace features longer than I have showers and there is a lot of safe guards you can preform to achieve some safety points in regards to mounting a TV above the fireplace.
Drywall many times is not permitted above your fireplace, most units require 8"-24" of a non combustable material above and many require non combustable material 2"-6" on the sides but not all.
Each fireplace will have a specification for mantle project. This is key to observe and the safety of your home and TV will improve or reduce depending on how well you follow this information.
Do you have an end look in mind?
If you visit www.houzz.com you can browse through tons of examples.
JW
Ok when we removed the rock the drywall came off with the rock what you see in the pictures is what was behind the rock ,the only thing I removed were 4 pieces of insulation between the header piece up top and the next horizontal 2x4 below it.
Make is a Heatilator wood burning only #'s that I could find were 479 #F360625 MARK 123 30380A on a tag riveted to the inside lip.
I went to their web site punched in the #'s and nothing came up.
I wasn't sure if I could have the drywall come up just to the outside of the metal frame of the fireplace ...?
I couldn't find anything on that from their website or ?
Basically , have it dry-walled with a mantel w/some type of tile ? around fireplace and have the TV mounted above..
JW
IF that heatilator fireplace is a zero clearance unit, are those standoffs still required? Just asking. Last Heatilator unit I installed was in 1973 and I surrounded it in masonry. with just some fiberglass blanketing it came with. That heatilator weighed a lot.
View attachment 16502View attachment 16503
Ok hopefully these will help more ??
I know on the flue pipe going up it has stickers on it saying Maintain A Min. 2in Clearance To Combustibles
I tried answering questions in your quote...
Sorry tried to delete one of the same pics didn't work ??
