Tom Sawyer
If it's a metered demand unit it does
No, that is for those not going with a larger softener to be able to get a regeneration on a weekly basis or to use Iron Out.Thanks Gary. I used the link in your signature and it stated that with an iron level of 2.0 I may want to regenerate every 3-4 days. Do you say on average once a week because of the type of iron it is compaired to 3-4 days?
If that is what it showed, that's what you need unless you want to regenerate more often. Sorry but you either buy the necessary salt for a softener or suffer the much higher expensive of living with your iron and hardness.By using the calculator in your signature's link I am getting 70k capacity to have a 24 hr reserve. By looking at the salt dose chart, I am going to be using a whole lotta salt, alot more than I thought I would anyways. I hope I am seeing this wrong, but at 6 lbs salt dose I will need a 3.5 cu ft resin bed?
Yes, add up the max flow rate of the fixtures you use at the same time or use a tub that has no flow restriction, whether you use it or not.I read how to use an outdoor faucet or tub but is there a way to be more certain? Can anything be added to these results to act as a buffer? Is the 7000 vs 5600 a matter of the valve porting and not the sfr of the resin bed itself?
Because you said at times a medical condition causes water use.
You use the SFR of the softener, not the control valve but... Fleck says to not use a 5600 on a larger than a 2.0 cuft softener (a 12" diameter tank), I don't recall the max for a 7000 but it is way up there around a 9-10 cuft (maybe a 21" tank).
He said he used water at night sometimes due to a medical condition.Not sure what he means by not using water the night of regeneration.
Not many users will ever know WHEN their softener regenerates, and since the standard programming has it going at 0200, it should be moxnix, unless you are coming home from the club and showering during a regen. In which case, you'd be using untreated water in the event of a single tank system (not a big deal once a week or so), or perhaps exceeding the SFR on a dual-tank system.
Oh I see new conditions now but, after 25 years experience with control valves, and comparing that to your is it two weeks experience with your first softener, - I can tell you that it is rare for Fleck or Clack valves to have wear problems regardless of how frequently they operate.And the wear to which F6Hawk refers (and it's not a fear, it's a fact) is simply being pointed out that a system that regens every night will in fact wear out 10 times faster than one that regens every 10 days (assuming "industry standard" parts, and that nothing is defective to cause premature failure).
I'd suggest the Fleck 2510 but... any dealer can sell you any size softener you need but they may not have it on their web site so you'd have to call them and ask them for one. Or you drop back to an "80K" and program for whatever salt efficiency and K of capacity you want to use.If this is true then it seems like the softener I am going to want is a 7000SXT with a 3.0 cu ft resin bed. 96k is the largest bed that I can find.
And as I think I've said to you, I'd go a 2.0 cuft as long as you don't need a higher than 13 gpm for your peak demand and regenerate it more frequently. If you need more than 13 gpm, go to a 2.5 cuft.
Yes, upflow is not an option on a 2510 and I'm not sure but I don't think it's an option on the 7000 either and if it is it has to be special ordered because internal parts are different than the standard down flow. You don't want upflow/counter current regeneration anyway, for residential softening it is mostly sales hype and usually not done right.thanks I saw them online and they appear to have great prices. But as far as my last question, does the 2510 only do downflow regeneration and if so is it a not so critical feature?
Yep, just about twice the water use, proving there is no "free lunch".at a frequency of 4 days regeneration instead of 8 with a softener that is 2.0 cu ft or 2.5, would I be using twice as much water since I regen twice as often?
You are a very wise man.Thanks again guys this has been a really big help. If not for this site and the responses I would have a Kinetico K2060 hooked up in my basement and have spent alot more money. The time spent on here was well worth it.
Yes it would, along with the additional capacity above your programmed K of capacity. Remember that the original new capacity was 30K per cuft of of new resin but, if you use any of that, you are not regenerating that resin with your salt dose for whatever K of capacity you are programmed for. I.E. a "32K" = useable 30K and you program for 20K (@6lbs/ft) including your say 3K of 24 hr reserve leaves that 30-20k= 10K still in the bed; unless you start using it by overrunning your SFR of 9 gpm. Then, with only 6 lbs of salt, you do not regenerate that part of the 10K or all of the 20K you need and you get hard water through the softener.with a 24 hr reserve wouldnt that be considered not waiting until the softener runs out of capacity? We were goign to take it one step at a time and first see how the water tastes.
Why are there places online selling them with up to 3.0 cu ft resin beds? Is this a disaster waiting to happen?Fleck says to not use a 5600 on a larger than a 2.0 cuft softener (a 12" diameter tank)
