ah2bwise
I have had 3 local companies come out to test the water. All came up with very similar results. I am in Upstate NY, the well is 308 ft drilled in December. Hardness is 28 grains, 2.0 Iron (they stated it was ferrous) no nitrates/chlorine/sulfur, TDS of 460, pH of 7.1, tested neg for chloroform and e. coli. It is my wife and I plus our toddler and new born. We plan on having more children. House is 2 bathroom.
I was quoted without install for a Kinetico K2060 + 10" filter and 6 salt bags at $2300, or a Powerline single tank no install with Fleck 5600 valve for $1198 + filter and salt. I called later for a price on a Fleck 9000; $1930. They said they could get a 9100 in but didn't have any in stock. After much research I would like to go with a twin tank system. They told me I will get hard water past the valve on the 9000 series; the Kinetico is better and will not do this. Also I will get more life or less parts replacement on the Kinetico due to the previous sentence, and the Kineticos are easier to service. I have read that the electricity that the Kinetico saves is equal to unplugging a digital alarm clock. They were pushing the Kinetico but I need to see a cost justification to go that more expensive direction. Not that i doubt there is one I would just like to see it.
My questions are:
Is this true what they said about the Kinetico vs the fleck valves?
If I order online is there anywhere I should avoid? I can google Fleck 9100sxt and under "shopping" there are a few places they are available and at less than I was quoted.
How much electricity does the Kinetico save?
Thanks in advance
My questions are:
Thanks in advance
