Moen shower valve moans
ahosh
Westchester, NY
Hey Guys,
I have a Moen shower valve in my home's main bathroom. I am currently renovating my master bathroom and to re-run soem plumbing and rough in the new shower valve, I had to turn the main house valve on and off a few times. Now the Moen shower valve in the main bathroom moans when I move the lever to the hot side. It is a single handle and it seems to make the moaning noise anywhere along the warm water side.
Any ideas why or what I can do to fix it?
Andrew
Hey Guys,
Andrew
Call Moen at 1-800-289-6636 Describe the problem to them and they will send you a free replacement cartridge kit.
Just had same problem.
Jerry
I just got around to replacing my Cartrige. Last week I attempted to break it free with the plastic "tool" included in the kit. No way would it budge. I called Moen and they sold me the REAL TOOL for $25 and shipped it FedEx.
I sprayed the old Cartrige with some PB Blaster 2 days ago. Tonight, With the REAL TOOL it came out. That tool works like a bearing puller where you can apply pulling pressure and at the same time slightly twist the cart. That did the trick.
The problem with that answer is that if it is a Moentrol valve the noise could be in the pressure balancing spool and a new stem will not cure it.
Mine was a positemp from 2001.
