kylrich
Hi, I recently put in a new expansion tank but since the change there has been a steady leak that seems to be coming from between the air scoop and tank. I only used thread tape, so i'm going to try block sealant to see if this resolves the issue. I'm not sure if it will because I may have discovered a hairline fracture in the air scoop female connection.
If the block sealant around the expansion tank does not solve the problem, I was curious how difficult it is to replace the air scoop. While this isn't a great view (something i have handy on my phone) it shows the the layout, air scoop, and tank. It appears there are threads on each side of the air scoop. Is it as simple as unscrewing the air scoop and replacing or is there some cutting and soldering needed here? If a better picture is required I can post one tonight.
Thanks in advance for your assistance.
