My old pressure tank for my well gave out yesterday so I was forced to replace it today. Our well is about 400 feet from our home on the other side of a hill. The incoming pipe is 1" PVC which I had to cut in order to perform the replacement. I had removed the circuit/safety switch prior to any work so the well pump had no power (I had also removed the wiring from the pressure switch). I was not surprised to see water come out after cutting the PVC pipe but I was surprised that it did not even slow after 20 minutes (I'd guess 1 gallon per minute). I decided that it might not stop so I used my PVC cement to put it back together while the water was flowing (I did open the drain on the new tank so no pressure would build up as I worked). FWIW - I was using the 2-part standard PVC cement (purple primer plus glue). The new connection is dripping a drop or two every 10 seconds. I know that I need to remove that weld and try again but I'm trying to figure out my best plan of attack to succeed the second time around. Also, how pressing is this? Do I need to repair it immediately or can it wait a day or two (I don't want total failure!!!). Thanks for any input!
