Pink water
irish girleen
ireland
Hi, I am new to this forum so I hope this question hasn't been asked before. We have a pentair water cleaning system. We have recently noticed that the potassium permaganate is ending up in our water tank. We have tried doing the obvious remedies but nothing seems to work. So the system is being bypassed at the moment. Any ideas on how we can remedy this?
Please list the remedies you have tried. What type of valve do you have? A restricted drain will cause improper flushing which may cause the problem. An injector with debris in it could be the cause. More info needed.
What water tank? Is it a storage tank that then water is pumped/sucked out of and then another pump or gravity refills it like a cistern from a well or rainwater, creek, river etc.? Or is it a storage tank on your roof and gravity feed to the fixtures? If so, assuming the filter is on mains pressure, what is your mains pressure in psi?
Is the time of day set correctly and is the filter programmed to regenerate when no water is being used?
Is there more water in the PP tank than normal?
How old is the filter or, how long have you had it? Has it worked in the past or not?
hehe, wouldnt surprise me. When the water comes out of the faucet like that, it is scary.
Personally, i like trying to rinse down pyrolox, that media is dirtier than... dirt.
Carbsorb is another, it can run to the drain looking like the river from Charlie and the chocolate factory for hours during the startup procedure. 9% ash doesnt help.
