Water consumption increase?
dmendiol
TEXAS
I increased my salt setting from 6 to 10 lbs. my water softener is undersized so it regens every 3-4 days. I think it was about once a week with the old setting.My water bill almost doubled! Yikes! How much water does a regen cycle consume? I checked for a leaky pipes and all looks ok. I think I am going to buy the new equip as suggested by some.
Tom Sawyer
Maine
dunno, what valve do you have and how do you have all the settings set? but at any rate you almost doubled the salt setting so yes, expect higher water use
ditttohead
Water systems designer, R&D
Ontario California
We need more information. Even a picture of the system would help. Changing the salt setting requires considerable reprogramming of the valve. Changing the settings in the valve incorrectly can cause massive waste. If you are considering new equipment, please give us your pipe size, bathroom count, any excessive water users (super bath tubs, rainforest type shower), hardness, and people in the house. We can recommend a size for you. Be sure the softener feeds the house only and no irrigation.
Gary Slusser
That's all folks!
To raise the salt lbs from 6 to 10 lbs is 4 more lbs of salt but 1.5 or less gallons of additional water (use) in the refill position to dissolve the additional 4 lbs. (3lbs of salt per gallon).
That is unless you changed (increased) other settings like the length of the backwash or final/rapid rinse, which you don't necessarily have to but....
You would have to increase your K of capacity setting or the number of gallons on a meter or the number of days on a day timer control valve. If you don't, you won't get any additional time (or gallons) between regenerations.
No softener should double the amount of water used before the softener was installed or put in service so, if yours has, there is something programmed wrong or a water leak. Check the drain line for water running out it when the control is not in a regeneration.
dmendiol
TEXAS
The system is a Fleck 5600 controller (metered) with a 10x44 tank, 48,000 grain. The manual specs reference 2.4, .45, 2.4 and .5 GPM for backwash, brine draw, rapid rinse and brine refill, respectively. The only thing I moved when I replaced the resin was what appeared to be the salt setting, a small white indicator with a screw on the back of the controller. It was at six and I moved it to 10. Is this even the salt setting? I also followed the instructions where it mentioned to set the hardness and the number of people. As for the size of softener, the consensus was 80000 grains/2.5 cuft of resin.
ditttohead
Ontario California
Thanks for the information. That system should not be causing excessive water usage from what you did. It is an electromaechanical valve. The electronic controls are commonly "adjusted" in the programming which can cause all kinds of problems.
The 5600 Electromechanical (Econominder) is a bulletproof valve. Simple intermittent maintenance and it will last 20 years.
Now to get technical,
10x44 w/ 50% freeboard = 1 Cu. Ft. of resin assuming the lower dome has a gravel base. most companies overfill them with 1.25 Cu. Ft. This is not a problem, it is just technically incorrect. (50% freeboard means 50% of the media height, or 1/3 of the non domed portion of the tank)
For your capacity, assume 24,000 grains removal with 8# of salt per cu. ft for regeneration. How much resin did you put in the tank? The total capacity of that tank, without gravel, just stuffed with resin is only 1.75 Cu. Ft. so your calculations are incorrect somewhere. Do not fill the tank, it should have 1 Cu. Ft. possibly 1.25 Cu. Ft. maximum!
The proper amount should have been 10 pounds of gravel, and 1 cu ft of resin, though 1.25 Cu. ft. is ok.
1 Cu ft = 24,000 grains capacity @ 8 pounds of salt.
1.25 Cu Ft = 30,000 capacity @ 10 pounds of salt.
Your Drain Line Flow Control DLFC should be 2.4 GPM
Injector, white
Brine line flow control will be indicated near the brine line on the valve, this should match the salt setting you were adjusting. Lets assume the BLFC is .5, it should have a black sticker near the brine line indicating this. Youer salt setting in the back of the valve should be from 6-36 lbs, newer valves go to 6-30 due to some minor recalculations that were done recently.
To set the meter correctly, we need to know the hardness and if any iron or manganese are in the water.
Dont bother with the people dial/hardness... just let us know how hard the water is and how many people are in the house and we can help you set it fairly accurately.
dmendiol
TEXAS
Injector, white
Sorry for the confusion. The 2.5 cu.ft is the number for the new softener I am considering.
I put in 1.25 cuft in the 10x44tank, so I am at capacity. The reading near the bloc is .5gpm and 1.5 lb salt/min. Hardness is 22 avg , no iron or manganese. 5 adults + 1 infant.
ditttohead
Ontario California
Here is the simple form of the calculation
6 people X 70 gallons ech = 420 Gallos per day
30,000 Grain system / 22 grains, = 1363 gallons system capacity.
Meter should be set to total capacity - 1 days usage, so... 1363-420 = 943 gallons. Set the meter to 900 gallons. The system will regenerate approximately every third day. It should regenerate no more than once every 5 days for proper efficiency.
This system is definetly unsdersized. You should have the 2.5 cu. ft system. I would highly recommend the 7000SXT for your application. An electronic controller will be able to monitor your usage and regenerate more efficiently.
Hope this helps.
FYI, even though your system is undersized, it will still work, it is just less efficient than it technically should be.
Gary Slusser
That's all folks!
You shouldn't use average hardness, use the actual hardness if you have your own well and the highest hardness in a city water system.
BTW, most if not all resin manufacturers say a residential softener should be sized to regenerate on average once a week. That gets you much better salt and water efficiency than regenerating every 5 days.
ditttohead
Ontario California
Gary is correct on the efficiencies. Their is a point of dimnishing returns though. Once you get past 5 days, you gain very little additional efficiency. Less than 5 and you lose considerable % of the potential system efficiency. I always prefer no less than 7 days between regenerations, but if you have a system that will go every 5th, you are doing fairly well. 7+ is better. More than 14 days should be avoided but... I have a lot of accounts that have had the 5600 with no "override" for 20 years with 1 person in the house, low hardness, regenerating once a month with no problems. Not recommended but...
Here is an old efficiency chart, these are stricly approximations, there are too many factors to make a perfect chart. This is the same chart we use for water cycles on a cooling tower or steam boiler. Once you get past a certain point, the efficiency gains become silly.
3 days = 66% approximate efficiency
4 days = 75% approximate efficiency
5 days = 80% approximate efficiency
6 days = 83% approximate efficiency
7 days = 86% approximate efficiency
8 days = 88% approximate efficiency
9 days = 89% approximate efficiency
20 days = 95% approximate efficiency
30 days = 96% approximate efficiency
50 days = 98% approximate efficiency
7 days gets you to the point where any futher out and your gains become insignificant.
dmendiol
TEXAS
Found the source of the increase in water
Found the source of the water increase...it was a leak right past the water meter. I just did not see it because of the surruonding mulch and recent rain.
Thanks for all your help, guys. It's nice to have access to a site like this--25 years ago this was unheard. Dial-up modems were the norm! LOL.
Gary Slusser
That's all folks!
IMO, using a chart used for boilers etc. to size or set up a residential softener is not the right way to go because normally the equipment is not the same nor is the water quality from a residential softener acceptable for most commercial boilers.
If we were to use the chart, I see a 6-8% increase in efficiency from 5 to 7 or 8 days and IMO again, 6-8% over the 10-20 years of the normal life of a residential softener seems like a fair amount of salt saved. Or, we could say a substantial increase in salt efficiency.
And I do not believe the "efficiencies" are talking about water efficiency, just salt used. Water efficiency would be greatly increased with 7-8 day regeneration.
Residential softeners should be sized and programmed for a regeneration on average every 7-9 days, using 60 gals/person/day.
Tom Sawyer
Maine
The actual difference between 5 days and 9 days is so small as to be of no consequence at all. I for the life of me don't understand the need to micro manage salt use. Yes, we should avoid excessive salt and water use but 99.9% of the time, if the unit is properly sized and set according to the manufacturers directions, the unit will perform just fine and requires no extra twiddling at all.
Those of us that actually sell, install and service these things on a daily basis are not so concerned with micro managing customers salt or water use. We want equipment that gets the job done efficiently and does not generate call backs that cost us money. It's easy to sell stuff over the internet because you don't have to install it or take responsibility for its operation.
ditttohead
Ontario California
Residential softeners should be sized and programmed for a regeneration on average every 7-9 days, using 60 gals/person/day.[/QUOT
We use the exact same equipment for commercial boilers as we do residential. For small steam boilers requiring <1-3ppm hardness as CACO3, any Fleck or Clack can be used to meet this water quality requirment. Just use your resin manufacturers hardness bleed charts. A hardness bleed of <2 ppm can be achieved by regenerating a resin bed with 12-15 pounds of salt per cu. ft. This is not an acceptable efficiency for most operators, so a pre-softener, usually a twin alternating design is installed ahead of the polishing softener. The pre softener is typically set to regenerate with 4 pounds of salt per cu. ft. BTW, I am a licensed steam boiler operator. leakage1.jpg
My charts are a standard efficiency chart. We use it to show the diminishing return past a certain point. In steam boiler and cooling towers we use this for water cycles. If I increase my water cycles past 6, the return on efficiency drops neglibly. Same goes for salt efficiency past 85-90% efficiency. Why not go to 14 days between regenerations from 7 days, that is an increase of 7%, over 20 years...
The point of the chart is not to create an efficiency debate, I will win that one every time. I was a system efficiency consultant for SCE and SCG, I know how to maximize systems efficiencies in softeners, electrical systems, Cooloing towers, steam boilers, lighting systems, motors, etc.
I will try to find the article I wrote 10 years ago on this exact subject and post it, otherwise look up Pentairs water/salt efficiency article. A cubic foot of resin uses a nearly set amount of water to regenerate. I agree that systems should be sized to regenerate every 7-9 days, but as long as they meet the 5 day minimum, the efficiency differences are no where nearly as dramatic as some people would beleive.
Tom has it right, a system set to regenerate with a proper amount of salt and I will add, systems should have their backwash and fast rinse times minimized to meet the supply water quality, then as an industry we will have met a much better standard than we have in the past. Considering the largest system people buy from Home depot will usually regenerate every day or two...
Now for micro managing salt usage, I used to sell millions of pounds of salt to commercial and industrial facilities, and we pushed for innefficent systems to increase our salt sales. Not a good way to do it, and we are now heavily regulated because of our short term thinking of the past. Also in the past, the technology was just coming in to allow for easy efficiency gains. I rarely sell single tank systems anymore for commercail applications, the majority of our larger system sales are almost always system 14 triplex designs. We do not need to micro manage salt, just properly sell systems that are sized properly, and set the salt to less than 8 pounds of salt per cubic foot and the customers will nbe happy, and we will keep ourselves from being more regulated. See the capacity vs salt chart aboe to see why 8 pounds should be the max. The efficiency curve drops quickly past 8 pounds. California allows for no more than 6 pounds for residential use. I do not like 6 pounds personally beacuase of the hardness leakage gets into the area where some people do not "feel" the full benefits of soft water.
Lets not start a debate, just look at the charts, nod , and dont start stirring.
Gary Slusser
That's all folks!
My Autotrol 440 timers on both the softener and iron filter came with a 6 day wheel.
The 440 is like 40 years old and it's a day timer. Autotrol has a number of valves that allow more time between regenerations. A metered valve on a softener saves substantial salt and water. You don't want a metered valve on most filters.
Gary Slusser
That's all folks!
Doing the simple math to come up with the lbs of salt required to regenerate the K of capacity needed to provide the gallons of water used to cause a regeneration on average every 7-9 days is not difficult if you know how. It isn't "micro managing" either.
You comment concerning selling water treatment equipment over the internet says to me (someone that has done a lot of it) that you've never done it.
Tom Sawyer
Maine
No, I have not nor will I ever sell equipment over the internet. If I can't put my hands on it to install and service it I sure as hell don't want the headaches of dealing long distance with problems, or having my product made unavailable to me anymore by the manufacturer. Clack took its products out of the internet environment because of the slew of warranty issues that were not being handled by the sellers and because their products were being sold by guys that have no clue. No, doing the math is pretty easy but that's not what I was talking about. What I'm talking about is those folks that get wrapped up in micro-managing the valve settings and never seem to be happy with their results or are constantly fiddling with an appliance that should be set and forget except for adding salt.
Gary Slusser
That's all folks!
And most boilers are not small stream but, we aren't talking to someone with a boiler. The OP and other residential softener owners are not testing their softened water for ppm of hardness. Residential customers use gpg, and as long as the softener produces 0 gpg of hardness, they are very satisfied.
I agree with your previous comments that that volume of salt use is very wasteful in residential applications.
A set amount of water only if you as the dealer don't change it or tell your DIYer customer to set it properly.
The 7-9 days is what I said.
I've been doing that for years and gave all my internet customers those figures and told them how to program their control valve. And since 1987 I programmed all the control valves on equipment that I sold to local DIYers.
Shame on you. I've never done things like that. I did what benefited the customer and if they didn't agree, I walked away from the sale. I got a very good reputation doing that and it enabled me to sell much more equipment.
I've been properly sizing softeners for many years based on fairly high salt and water efficiency and rarely had any complaints from customers suffering hardness in their softened water. And usually found that they had allowed the softener to run out of salt a week or so earlier and didn't follow my instructions of what to do when they did that.
Sad to say but many dealers today are still not sizing or programming properly.
Lets keep discussions on doing the best for the OP here, nod , and don't continue stirring with "Tom" et al.
