I need a timer for a bathroom fan/light/heater combo.
Erico
Chicago, IL
The plan is to place the heater on the timer and switch the fan and light.
I have to check again, but I believe the heater is rated at 1000 watts.
The largest wattage timer I have run across is 600 watts.
Can anyone steer me to a supply house who carries higher watt timers? Perhaps my google fu isn't up to snuff.
Here is what I have found and what I had in mind (only higher watt timer).
http://www.iaqsource.com/product.php?p=ps_3funswieletim-i&product=172673
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17139&minisite=10022 has at least a few that are rated at 1800W. Depends on the style.
Thanks for that.
For some reason, I have the hardest time navigating their site.
I still can't find the double rocker switch on their site. I know it exists becauuse it's on HD's website here:
I sure would like to read the specs, Can find it under HD's published MFG model #.
I assume a regular 15 amp double rocker would do the job of running the fan and light. Not sure what kind of wattage these switches are or what my fan uses.
A fan is likely less than 200W, probably a lot less. As to the light, most won't hold more than about a 75W bulb.
Some hair dryers are 2000w, does everything you plan to hook up here seriously draw that much power?
The link I pointed him to provides several choices of timers that can handle 1500W and are electronic. Now, they are not a combo switch with a second/third switch for the light and fan, so he would need a multi-gang box. Sometimes, the fan manufacturer sells a combo switch deisgned for their product...since he did not indicate a brand for that, I didn't search for one, but he should. But, many places have their fan/light wired with two switches, so you could get a combo switch for those two functions, and put the heater timer in the other place in the box - or, just make the box bigger.
You will probably need a rotary spring wound timer to handle that amperage.
I think you are correct. That's the way we will go. Also, I don't know if there is a nuetral in the switch box and some of those push-buttons require a nuetral.
Yes, you did. And thank you.
It's an old broan fan/light/heater original to the house circa 1971. It does have a proprietary control now.
I need to add switches so I'm cutting a little drywall anyway and intalling a 3 or 4 gang box.
I haven't pulled it apart yet so I'm not sure what those things went in to? Would it be a regular 2-gang box?
At this point, I'm leaning to a mechanical winder timer because it appears some of thos push-button timers require a nuetral and I don't know if there is one in the switch box.
