Tom Sawyer
Please, let's not turn these threads into CSV bashing. A CSV is certainly a viable solution to many problems and should be considered when ever the need arises.
That's because I didn't use a "?" for punctuation. What I said was "I would like a few examples of such a draw on a residential system.".I can't find a question in your post..
I see the CSV as a good product for a Oversize Pump or a Undersized Tank.
means nothing! Many experts test improperly. A CSV is an excellent and inexpensive addition to any private water system regardless of the pump and tank sizing. It will give the consumer a constant pressure (like when taking a shower) and will extend the live of all components in the system.Have exhaustively tested
So if You have a CSV, It should last for 100 Years ?
I need one of them. I must be getting old, I do not understand the problem with Old School.
Have a Great New Year Texas Wellman, and All.
Some people like Fords and some prefer Chevrolets and then there are those that don't know the difference!means nothing! Many experts test improperly. A CSV is an excellent and inexpensive addition to any private water system regardless of the pump and tank sizing. It will give the consumer a constant pressure (like when taking a shower) and will extend the live of all components in the system.
We have a five-year written warranty on our complete kits. We know the kits are installed correctly. But we never have any warranties. I replace a few valves as a courtesy, which are packed full of sand or have frozen and busted, but rarely a pinhole or any real defect. Send me a 19 year old CSV with any kind of manufactured defect, and I will replace it at no charge. Standing behind our product is one thing we are not afraid to do.
Also, prove to me that a properly installed CSV caused the failure of any other part of the pump system, and I will take care of that as well. How is that for a warranty?
No, a real test would be (and was) a side by side comparison of the product under the exact same conditions. The testing that we did showed that although "pressure" does remain fairly constant with a CSV, under residential conditions (varied draw times and varied draw volumes) a properly sized pressure tank showed about 6% less pump cycles with run times averaging only slightly less than with a CSV installed. These draws ranged from 10 seconds to as long as 15 minutes. In both cases a long draw from a high volume source ( in our case a direct 5/8 line off the pressure tank ) caused the pump to run throughout the duration of the draw with no cycling of either system.
I have never seen any published data curves based on actual random use testing published for either your product nor the ****** CSV
As far as a CSV damaging the pump I think that would be highly unlikely as restricting output actually causes the pump to draw less amperage and operate at higher velocity which theoretically should not be a problem although several pump companies did initially refuse to warranty their products should a CSV be installed in the system. As far as I know though, those restrictions have been dropped.
