BobL43
DIY Senior Member
I do have 8 skylghts already in the roof! they work well.Good stuff Bob.
Sky lighting sounds like a better way to go.
To bad it is not as easy to install.
What is in the LED light that makes them a hazard ?
Neodymium, and other rare earth minerals. Same is in the displays on your pad/pod whatever. Prices will rise as china starts to bogard their supplies. That is also true for lead, such as smaller sealed lead-acid batteries. Most of the worlds lead is now mined in china, and environmentally it was so out of hand, even china could no longer ignore it ,so some mines were temporarily shut down. Just starting to get back up to speed.
I have heard the term "Don't bogard that Joint"
Thats a good song too...
where are you buying LED lights so cheaply? $25? where? do tellI see one at big orange that i kind of like, since i am remodeling. i thought they were more like 50 or 60 each and came with trim. someone mentioned CREE, i think those are the same lights. they fit in a 5" or 6" can.
I thought I turned my webcam offI have heard that they don't work well at night.
But it must be very cool to be able to Howl at the Full Moon from your Arm Chair...
was a little tongue in cheek there, mtIf you're doing the can light conversions, you don't need permits/electricians. Its just changing a light bulb. The ones I'm thinking of screw into a standard base and just replace the bulb and the trim on the can light housing, no electrical requirements.
Back to $250, seem more reasonable?
Although, I think if some people had their way about things, this would be a permit operation requiring union electricians and all that jazz... <sigh>
on HD's web site, the Model ECO-575L sells for $39.99, but at my local HD's, they are selloing for $24.99. They come with trim, which is integral with the bulb.where are you buying LED lights so cheaply? $25? where? do tellI see one at big orange that i kind of like, since i am remodeling. i thought they were more like 50 or 60 each and came with trim. someone mentioned CREE, i think those are the same lights. they fit in a 5" or 6" can.
Heh, I realized that after posting... guess I'm flying through these posts a little too quick...
