Bath Sink PTrap Options ..
Beachfront71
newport beach, ca
Hi and thanks.
We are dropping 2 vessel sinks on top of an old dresser we had refinished.
In order to try and conserve/use as much of the drawer space below the sinks I was loooking for some answers to the following:
1. Is there a minimum distance a ptrap should be below the drain hole of the sink?
2. Could I run the drain down 5 inches then elbow towards the wall, then put the ptrap in and go down to the ABS stub?
Any other suggestions appreciated! Using 1.5 compression fittings from home depot if it matters..
BTW. All of this will be inspected by the city.
Thanks again for any and all time spent/
Your quetion #2 would create an "S" trap which would NOT be approved by the city. The "ADA" drain will NOT have a stopper or popup drain and would NOT normally be suitable for a bathroom fixture, besides usually only being available in Chrome finish. If your vessel sinks do NOT have overflow openings, then HOW you connect from the sink to the trap will have a lot to do with how well they drain.
Thanks for the info ..
And yes, the sinks do have an overflow on them. and we do have pop up drains ..
How far down does the drain need to go before adding the ptrap?
If this distance is minimal and I can put the ptrap close to the sink, then run everything back to the wall then down and out .. that works!
THanks again.
There is no minimum vertical distance between the drain in the sink and the start of the p-trap. Usually, the vertical section directly below the drain is needed to accommodate the pop-up drain mechanism (open/closed). If you don't care about a pop-up mechanism, you can offset horizontally directly below the drain closer to the wall, and then drop into the p-trap - that is how the ADA drain would work. This is also similar to what happens under a bath tub.
The key issue that the other posts are referring to is the vertical height of the connection after the p-trap. You cannot drop vertically after the p-trap until you connect to the vent. If you do, you effectively create an 's-trap', which can cause drain problems, including siphoning of the trap. This is why there is a suggestion to 'raise the stub-out'. Raising the stub-out means opening up the wall and cutting pipes, and moving the fitting up higher to the proper height for the p-trap exit.
Also consider that the longer the piping is before it gets to the trap means more length of pipe that can get crud accumulated in it to start to smell. The trap, filled with water, masks any smells that may be there beyond that connection.
Thanks for all of this and the explanations .. makes total sense ...
Last question -- if this does not work than I am doing the normal down to ptrap across to ABS...
So from the sink drain .... Could I
1. Down 4 inches to an elbow
2. from elbow, back towards wall 10 inches to another elbow pointed down
3. now go down 12 inches into ptrap
4. from ptrap directly/horizontal to wall (3 inches)
This gives me all the room I need and lets the overflow drain pop up .... just want to make sure I can go horizontal and vertical before ptrap .... only horizontal after...
Yes, that should be fine. Your 'horizontal' section should still have a small slope - you don't want water sitting there. Jim mentioned the downside of the extra pipe before the trap. Worst-case would be that you need to take it apart and clean it at some point. If you are not happy with it long term, it is always easy to convert back to the 'standard' install (p trap directly below the drain).
