Hello
I just brought this pump and have a couple of questions. I will be drawing the water from the lake useing 1 1/4 inch plastic pvc pipe. I believe the inlet and outlet of the jet pump is 1 inch in size. The motor sits on top of the Tank.
If i am correct i need a 1 inch tee that goes on top of the motor in the outllet hole. I believe i then hook up my copper supply line from the cottage to the side of the tee and put a plug on top of the tee that i can undo when needed to add water to the pump.
I hope this sounds right. Do i use brass or galvinize steel for the tee and plug? Is there an easier way in conneting the pump to my supply line to the cottage.
I am newbie so go easy on me lol Any help would be great
Thank You
Sudsy
Thank You
Sudsy
