A linear drain is bigger, thus, if you aren't careful when installing, there's more places it could leak. But, if you are careful and follow the instructions carefully, they should be as reliable as a conventional drain. And, they open up other choices for floor tile (i.e., the possibility of larger tile that wouldn't fit on a concave base). Keep in mind that smaller tile, generally, are a safer option, regardless, since there are more grout joints - this gives you more potential grip while standing there. SOme tile are VERY slippery, and you should choose carefully for any that you want in a wet floor area.
