Need advice
itsmeboat
HARTWELL, GA.
I have a 6" casing drilled well that is 800 feet deep. At one time it serviced 3 houses but is only used now for watering at
our house. The pump quit and when I put in a new control box it blew the bottom out of the capacitor. After reading many of your
posts I started pulling it today. I built a 12' tall derick with scafolding and used 4x4's at the top with a large wheel as the guide
for the pulley. The pump is being pulled via an electric winch attached to the scaffolding. I made a pulling clamp and a safety clamp
using 2x6" and rubber inserts with a hinge and clamp. I made a 3' t-bar and screwed that into the top of the pipe T and cabled it
to a sturdy horse via rachet straps. Once i got the rubber cover and bolts off I could not see a pitless adapter. I lowered the
1 1/4" pvc down with the rachet straps until the T handle was resting on the casing. Way too much weight to lift so I started with the
winch and managed to pull ou 60' late today....with another 200-400' to go.
My questions:
At 60' there was a check valve, I'm assuming there will be more.....how many do I really need?
Would you put new 1 1/4" pipe in when you replace the pump?
Should I dig down 3' on the outside of the casing and install a pitless adapter as far as I can reach in the casing?
Planning on putting the new pump down 200'...can I use less than the 1hp I currently have.
Is it worth putting a recovery rope attached to the new pump for down the road?
This is a slow process but I am not in a hurry...Thanks for any advice or comments. Don
From your description it sounds like it's hung on galvanized. Since you're doing this DIY I would go back with sch 80 PVC with stainless or brass couplings. You can go back with 1" to save a little money if you're only using a 1-HP pump.
You only need 1 check valve-the one installed at the pump (built in). I don't see why you need a pitless in GA. Pitless are for freeze prone areas, the sanitary seal you have now will work just fine. No safety rope or anything else because it can cause more problems than it solves.
Your pump size depends on your water level and your water needs.
