Water heater shutoff???
moonapprentice
central wisconsin
my Gas water heater is starting to leak at the bottom of the tank base and is going to be replaced real soon. I am leaving my house for 1 week and am going to shut off the water heater inlet ball valve in case any thing happens while I am gone. I was wondering if It is necessary to shut off the burner as well or if I could keep that on.
Just set the thermostat on the heater to vacation. That will allow the pilot light to stay on . Then when you return home you won't have to relight it.
John
Relighting the pilot light is not a very difficult thing to do. If the leak worsened while you were gone and the tank drained dry they could be serious problems if the heater kept trying to heat. Turn the gas off.
