That is a check valve, and it is NOT an approved "backflow" preventer for an irrigation system, unless ALL your zone valves have integral vacuum breakers on them, but then you would not need the check valve either. Take it out and install the correct type of valve, either a "pressure backflow preventer", or a "reduced pressure zone backflow preventer" whichever your area requires, but NOT an "atmospheric vacuum breaker".
