Water Saving Toilet.
Giles
Retired tool & Die and Mechanic
N.W. Alabama--Florence--
I have three nearly new toilets in a new to me home. They work perfect but, as you know, use a lot of water.
I have been told that a special "flap valve" can be purchased to allow water saving or regular flush.
Do these work as advertised?
Any toilet sold since 1992 uses 1.6 gallons or less.
1.6 gallons unless someone has changed out the flapper during that time, which would mean that you are draining the entire tank instead of letting out the 1.6 it was designed for. If you are draining the tank, then you're using 2.5 or more.
Can you attach a picture of what you have?
New water saving toilets have the Watersense label. Watersense is 1.28 gallons or less.
