Need help with shower valve cartridge replacement. Gerber, Harden Brass, and Matco-No
farmoci
South Carolina
Hi -
I am trying to replace the shower valve cartridge for my single handle shower faucet. The plastic lip of the valve cartridge is broken . . . unless I turn my handle just right, my shower will leak! My problem in replacing the cartridge is that I don't know who the manufacturer is of my single handle shower faucet. Because I couldn't find a replacement, I actually glued the broken plastic piece back, but that only worked for about a month. Does anyone have any suggestions for tracking down replacement cartridges? The only identifying information on my faucet is "UPC" and "CSA", which I suspect is not unique to this manufacturer. Attached are some pictures . . .
Have a look see here...
https://www.arpny.com/
Click on "single lever faucet cartridges"
You will find it I guarantee it!
I would have looked it up for you except my PDF reader is acting up tonight and shutting down by internet browser...
Okay I got it to work finally!
That cartridge was used by Gerber, Harden Brass, and Matco-Norca and is available at the link I posted above.
BUMP
I think this is the one I have too. I'm trying to replace the handle and need to either figure out how to remove the whole valve assy and replace it, extend the shaft on the cartridge to 3" to accommodate the new handle assy, or replace the cartridge with one that has a long enough shaft. Please help.
UPC is NOT a brand name. It is the "code" seal of approval granted by IAPMO ( International Association of Plumbing and Mechanical Officials). UPC stand for Universal Plumbing Code. Most jurisdicitions require all plumbing materials to be approved by a recognized approval body, like UL for electric). IAPMO is a universally accepted approving agency.
And it seems this post is in the wrong thread. I can't seem to find where you started this discussion.
Thanks!!
This thread totally saved us today. Amazing that 5 years later this is still good information. Thanks!!
-A
I found at New York Replacement Parts - Plumbing and Heating Supplies.
NYRCORP . com - Part# GERBER Single Lever Cartridge - 95-154 CARTRIDGE
Thank you very much.
Faucet was sold by Sears, they said lifetime warranty. When I called I was directed to "Foremost" There reply was Foremost is out of the faucet business . So much for the lifetime warranty.In fact they offered no help in finding out where I could get a replacement cartridge.
Thanks to this forum I may luck out yet.
