I am installing a one piece 32" shower in a corner of a basement. The walls are block. I want to build a frame for the enclosure. Do I need to put a vapor barrior against the block wall where the shower will be located? Or do I just stud up the wall and install green board before shower stall is in place. Also, do you build a platform for the shower to sit on? Any advise is very much appreciated as I do not like to cut cost on a job that is done right. Blomme.
