Turn off the water and open some faucets.
If it's electric, turn off the breaker first.
You only need to drain the tank below the connections, and if those are on top, not even then.
It is only under pressure until you turn off the water supply and open a faucet. As long as what you are doing is above the water level in the tank, it will NOT leak water out.
