AllIwant4XmasIsH2O
I'm going crazy! My husband is out of town and I've tried to handle this stuff by myself but I'm not having any luck and I can't get ahold of my neighbor. I think the pipes froze last night, thanks to our 9 degree weather, so I got a heat lamp out and set it to thaw out part of our line where I thought it may be frozen...5 hrs ago. Still no water. I went to the basement (heated) to see if the the blue pressure tank had water in it...it doesn't and I noticed there is no pressure in the tank. I checked the fuse box and all is fine there. Being that there is no water in the tank and it's possible my lines are still frozen somewhere should there be any pressure in the pressure tank??? Could that be my problem? Thank you for your time!!!
~All I want for Xmas is water
Edited to add: I went back to check well line coming from pump and I can feel a vibration in it, not sure what that is from. I have all faucets on in the house, in hopes that will help. I have an air compressor that I can use to put air in the pressure tank(I think the correct term is the bladder???) if needed but I have no idea if that's the problem. Dang I'm in over my head.
Please help.
