I just installed a new pressure gauge, and inflated my pressure tank to 38 PSI for my 40-60 switch.
My new problem is that my switch and pump don't cut in (turn on the pump) until the pressure falls to 35 PSI. It cuts out (turns off) at 62 PSI, which I'm not too worried about. It seems like my pump runs for a long time from 35 to 62, and I'm concerned that it may overheat. I'm also concerned that the pump cuts in at a lower PSI than the pressure tank is set at.
Can I adjust my switch so that it cuts in at 40 instead of 35 PSI? Or do I need a new switch? Or should I just reduce the PSI in my pressure tank to 33 (2lbs below the cut in PSI)?
Thanks.
Thanks.
