Zurn neo-seal
Potterboy1
New York
Has anyone had problems with the neo-seal leaking? Either after initial install or after a period of time in use? I am thinking about using it on a American Standard Yorkville rear outlet toilet.
I see failures all the time in a building that is full of these, but I think it has more to do with the install than the gasket (as long as you don't use wax, which is guaranteed to fail.)
jfarnold
What did you mean by "I think it has more to do with the install than the gasket"? Was it that the flange was not square to the floor/wall or improper glueing? I would like to know so I don't make the same mistakes.
He may be refering to a crooked pipe or a rough-in thats not quite on center line
