Runs with Bison
I can always lower the pressure at the regulator in the meter pit.
I thought you said the tee for the toilet was before the regulator? Are you saying there is a second regulator?
The fluidmaster has two adjustments for height...the fine one you adjusted on the float, and a second one to adjust the total height of the tower...if I remember correctly, you twist the whole thing like a screw, and the thing expands. You may need to remove it from the tank to have enough clearance to do it. It is described in the instructions, which you probably didn't read...
I would pick up an assembly cap at Lowes Hardware and replace it.
$2.47 near the Korky parts in the plumbing section.
No tools, and less then a minute to replace.
