Budget for a new WH soon. If it is rusting and leaking there, the anode is long gone, and replacing it probably won't help much. To get it out, you may need an impact wrench and a lot of luck. If you use much more torque, you'll need someone to hold the tank so you don't twist off the connections to the water and gas, creating even more problems.
