Gary Slusser
That's all folks!
- Messages
- 6,921
- Reaction score
- 22
- Points
- 38
- Location
- Wherever I park the motorhome.
- Website
- www.qualitywaterassociates.com
Bob, state your experience in selling and servicing softners with a Tubulator distributor tube or... call any wholesaler supplier of softeners that sells the Turbulator distributor tube and ask them if I'm right or wrong about increasing the size of the DLFC. Or try Pentair's web site for the instructions concerning the use of the Turbulator distributor tube.Contrary to the view posted above I don't believe that it is necessary to increase the size of the DLFC when installing a Turbulator. In my experience Turbulators work just fine using the same size DLFC as would be used with a standard distributor.
Of course if you do increase the size of the DLFC, as the poster apparently does, then it is understandable that bead breakage and excessive wear could occur. This is a great example of a salesman creating a problem and solving it with his preferred equipment.
Or look at the pictures below of a regular 1.05" OD DT (the gray one) and a 1.05" OD Tubulator DT and tell me how the same gpm flow of water down both types of distributor tubes is going to equally backwash the resin when the Turbulator DT diverts a 1/2" flow of resin and water up the side tube of a Turbulator.
Also tell us how you think the Turbulator softener still gets the same bed expansion of a minimum of 50% of the bed depth that all resin manufacturers require for proper backwashing of their resin when a 1/2" flow is diverted from the backwash water flow wit ha Turbulator. The ID of both distributor tube types is 3/4".
