Bob999
Please post your water analysis again--this thread has gotten so long finding it if it is posted is difficult.
Hardness 10?
Iron and manganese (I will assume none)
pH
City or well.
I understand you have a 1 cubic foot unit with SST-60 resin and your AN filter has calcite (only). You say two people in the household--I will assume 60 gallons per person per day unless you have better specific information for your water usage.
If you have iron in your water the 4 day regen for the AN filter is good. If no iron then 7 days would be my recommendation.
You should program your softener so that it regenerates every 8 days based on average use so determine the capacity used in 8 days--2 people @ 60 gal per day equals 120 gallons at 10? GPG hardness is 1200 GPD or 9600 for 8 days--round up to 10,000 grains of capacity. Now you need to deal with reserve capacity because the softener is typically set up to regenerate in the middle of the night (only) and there needs to be sufficient reserve capacity to ensure there will be soft water between the time the meter reaches the capacity setting and the regeneration time. The specifics of reserve are determined by the valve (and the specific model with the Clack WS1) and programmer choice. Once you determine the total capacity needed (10,000 grains plus reserve) this will determine the salt dose. You can refer to the literature for SST-60 resin to determine the relationship between salt dose and capacity. The literature is for new resin and most installers also include a factor to account for the fact that the regeneration efficiency will degrade a bit over time.
Set day override to 8 to ensure regeneration at least every 8 days.
Hardness 10?
pH
City or well.
