Connecting pipe to new shower valve
newmex999
nm
I am installing a new shower valve and have the option to sweat the 1/2" copper pipe or attach the pipe to the male threaded connectors on the valve.
Which one should I go for? Sweating the pipe on or "screwing" it on
Sweat a short piece of pipe into the connectors, screw these assemblies into the valve, then use a coupler to connect to the pipes. You have a couple of extra joints to sweat, but it's best to avoid applying heat to the valve assembly.
He has MALE connections on the valve, so the adapters would be screwed ONTO the valve. Why do that when the tubing will slip into the valve and solder to it, avoiding a threaded connection?
I've soldered a lot of pipe in my house so far with no leaks, but can see why the threaded adaptor to pipe option might be considered. I thought of going that way too when I did mine. Why? I thought (which might be common among non-pro plumbers):
- hmmm, if I mess up the joint to the valve it's going to be a pain in the butt to undo it and if I solder to the adaptor I can always unscrew it, toss it and start over (always thinking the worst)
- threads seem to be so much more 'friendly' than soldering, only a wrench and tape is needed (though yes, you still need to solder on the pipe to the adaptor)
Without being an expert plumber, I like many others I suspect always look at every possible way of doing things and try to figure out the simplest yet most goof-proof way of doing something.
Every time I solder pipe I get nervous that I'm going to mess it up. I always take my time to do it as good as I can, have never had a leak. But when you don't do it that often, it's always "did I do it right?" "did I put in enough solder?"
