Bob999
You are using book knowledge and attempting to apply it to real world situations without real world experience.
At one time Bob I sold solution feeders and serviced many that other dealers sold. You have one and love it, good for you. I refuse to sell them to my DIY customers because of all my experience with them and people telling me of their problems with one over the 13 yrs I've been been on the internet and in emails.
You are making incorrect assumptions Bob. I don't know what you are oxidizing and/or disinfecting with only 4 ppm of chlorine but you need a least that much or more for each ppm of iron, plus a variable amount for bacteria and then so much for H2S etc..
How are you controlling the solution pump, a flow switch or the well pump pressure switch? And you think that 10 gals will last all but 5 months for a family of 5, go try that with a customer and see how it goes with ever decreasing solution strength. Good luck with that.
I hope that people reading this don't take your figures to heart.
Gary--the 4ppm was an example. Changing the treatment rate within a fairly wide range will not change the conclusion because the treament rate is adjusted by varing the dilution of the chlorine injected in the example i posted. (I.E. so long as the injection pump is a 5 gallon per day pump and the well pump is producing 22 gallons per minute and the daily use is 400 gallons the required injection amount will be slightly less than 9 ounces per day.)
In the example I stated that the chlorine feed was before the pressure tank. As you probably know when the feed is done that way the injection pump is typically controlled with the well pump pressure switch.
I am using verifiable data and well explained calculations to raise questions about the assertions you have made.
I suggest you post your specific assumptions that support the statement you made: "a larger than 15 gallon solution tank unless the person is going to refill it every few days or weekly" so that we can deal with facts in this discussion.
