pipe
You cannot repair ANY pipe without being able to move the two sections apart far enough to insert the repair, either by flexing them or spreading them. If you cannot move the two ends you either need to use a union or multiple fittings to create a means of fitting things together. DO NOT try to insert the pipe into a fitting, and then pull the fitting back onto the other side.
