pwelsh130
I have a Cast Iron Vent Stack that the Kitchen sink assembly connects into. The problem is the horizontal drain pipe that connected into the sink was cracked next to the vent stack connection. I can not remove the threaded nut that attached the original horizontal pipe (took the broken pipe out but not the nut) to the vent stack. It is tucked into a concrete block wall and the pipe wrench can't get a grip. Any suggestions?
I have tried penetrating compound....Attaching a pvc pipe with epoxy. I put a torch to it but no help. I'm out of options. I've attached some pics.
