Plumbing Bathroom in basement - help
cheese1478
Kansas City
I am installing a toilet and sink in my basement. There is an existing 3" drain pipe that ties to 2 other toilets upstairs. The pipe goes down my basement wall and under the concrete. I broke out the concrete and will tie my toilet into the 3" pipe (18" away). I will also tie my sink into the same 3" pipe prior to where it hits the concrete.
Is this OK? Also, do I have to run a separate vent or can I vent throug the 3" pipe? If I can use the existing 3" pipe do i need to tie into or just use my toilet connect as explained above. I can find any other vent pipe?
Thanks,
First you can not have three toilets on 3".
Second you do need a separate vent for the new 1/2 bath.
John
I now understand the 3 toilets on a 3" pipe is not code. Assuming I find a different pipe to tie into for the toilet what is the best method to vent the toilet and sink? Any guidance is very much appreciated.
Any vent must terminate through the roof. If you connect to any existing vent it must be connected above the flood rim of the highest fixture on that vent.
Welllllllll...... actually, by the latest edition of the IPC, 3 toilets can go on a 3" line.
Sorry guys I guess I'm old school. We were allowed three on 3" on a vertical line. Back in the days of 5 gal. per flushes.
John
