Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > HVAC Heating & Cooling
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 11-03-2009, 05:00 PM
Lakee911's Avatar
Lakee911 Lakee911 is offline
I&C Engineer (mostly WWTP)
Send a message via AIM to Lakee911
Default AC Refrigerant lines: Braze or Solder?
When my furnace/AC fails in my rental house (and it will one of these days), I'm contemplating replacing the unit myself.
I've always seen the AC lines brazed. Why aren't they soldered? Can they be?
Thx
Jason
  #2
Old 11-03-2009, 06:24 PM
Bill Arden's Avatar
Bill Arden Bill Arden is offline
DIY Senior Member
The reason they are not soldered with lead solder is that the lead solder causes problems in the system.
You can still use low temp brazing solders and a map torch, however you can't use plumbing solder.
__________________
Important note – I don’t know man made laws, just laws of physics
Disclaimer: I'm a big fan of Darwin awards.
  #3
Old 11-03-2009, 08:23 PM
jimbo's Avatar
jimbo jimbo is online now
Moderator and Plumber
"plumbing solder" hasn't had lead in it for many years. But soft soldering, whether you use lead bearing solder or not, is probably not rated for the pressure of an HVAC system
  #4
Old 11-06-2009, 09:25 PM
rzyzzy rzyzzy is offline
DIY Junior Member
You might want to just hire the brazing done. You're supposed to flow a small amount of nitrogen through the lineset while brazing to prevent the pipes from getting black residue inside them - the residue could ruin your compressor. You can cook the valves if you aren't fast with the torch, and if you're too fast, you'll get a leak.
Around here, I've gotten quotes of $200-ish for an hvac guy to braze the lines with nitrogen, vacuum them out (to remove moisture), and check the refrigerant levels. Still a huge savings over letting them do the complete install. Many hvac guys won't want to help you with your install, but you only need one to break ranks....
  #5
Old 11-07-2009, 07:26 PM
rickst29 rickst29 is offline
DIY Junior Member
Talking There *is* a solder which works great....
but you will not find it in an orange or blue/white "big box" store. The problems with plumbing solder are: #1, the joints are too weak; and #2, it can't handle the stresses and vibration which A/C lines experience.
Stay-Brite-8, however, does a fantastic job, and it also begins to flow at an extremely low temperature. (That's handy when working with heat-sensitive components like TXV's). It costs a lot, though. Here's the mfgr page: http://www.harrisproductsgroup.com/c...loys.asp?id=32
It's best matched up with their "BRIDGIT" Water Soluble Flux, because that product also begins cleaning up the metal at just a little bit above room temperature. Be careful to avoid burning the flux-- that black gunk isn't good for compressors, either. They make a 95/5 formula too, but I'd pay the extra bucks to use the stronger 92/8 product. If you won't be using a lot of it, people sell partial-spool chunks on **** for much less than the cost of a full Spool from your HVAC supply house.
  #6
Old 11-08-2009, 06:50 AM
hj's Avatar
hj hj is online now
Moderator & Master Plumber
Default solder
#3 is that the residual flux will contaminate the compressor oil. NO ONE here purges with Nitrogen, unless it is for a medical gas installation.
  #7
Old 11-08-2009, 08:45 AM
jimbo's Avatar
[quote=hj;231347. NO ONE here purges with Nitrogen,.[/quote]
Probably true for a wide range of folks working on HVAC equipment now., even though the nitrogen purge is considered a "best practice".
After Jan. 1, 2010 ( when all new equipment will be R-410) there will be an uptick in sales of purging rigs, or a lot of guys will be destroying brand new units! The manufacturers are quite insistent the the purge is MANDATORY when working with R410.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
