#1
I am in need of finding 0.75 mfd - 330 VAC capacitors. Can anyone help????
SNYD |
#2
I would try:
Radio Shack Allied Electronics Mouser Jameco Allied probably being your best bet. |
#3
I should think a higher voltage rating like 370 volts would be ok so long as it was still .75 mfd.
So might have better luck searching for this by not including "330". Also capacitors are abbreviated uF So maybe search for .75uF capacitor AC or... .75uF capacitor 370 AC or 370 vac capacitors (Might call and ask some of the places you find with the last search.) |
#4
Any electronic store such as the ones mentioned, or Frys, should have something. What is your application? If it is something like HVAC then a 370 VAC might be a better number. 1.414 X 240 = 339 volts!
But if the application calls for 370, it is available I am sure. In most applications, there is no downside to using a capactor with a higher max. voltage rating. |
#5
Quote:
Two 165v 1.5 uF in series will give you 0.75 uF @ 330vac [but you need some voltage sharing resistors] , or two 0.375 uF 330v in parallel will give you 0.75 uF @ 330v. And what's your tolerance on the 0.75? Last edited by Thatguy; 11-03-2009 at 04:17 PM. |
#6
The voltage rating on a capacitor is essentially its insulation rating...the point where it might short out by flashover or piercing the insulation layer. So, normally, using one with a higher voltage rating isn't an issue.
__________________
Jim DeBruycker Important note - I'm not a pro FWIW - Don't try to buy a phone from Nokia on-line |
#7
http://ca.mouser.com/Search/Refine.a...VAC+capacitors
Do you have a parts number? or a company? Check this out, maybe, http://ph.mouser.com/Passive-Compone...tors/_/N-5g7r/ http://itemlistings.****.com/sdcsrp?...52&xm&var=ngvi Do a search on e b a y I found one. Type in, MALLORY 72-86MFD 330 VAC PSU7230B 235-9528-04 CAPACITOR I would think, this would work, 9.50. If I am wrong, please don't chop my head, just not enough information, but i hope this helps. Last edited by Cookie; 11-03-2009 at 10:30 PM. |
| Bookmarks |
| Thread Tools | Search this Thread |
| Display Modes | |
