Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > Electrical Forum discussions
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 11-03-2009, 09:22 AM
SNYD SNYD is offline
DIY Junior Member
Default Need Help Finding 0.75 mfd capacitor
I am in need of finding 0.75 mfd - 330 VAC capacitors. Can anyone help????
SNYD
  #2
Old 11-03-2009, 10:32 AM
PEW's Avatar
PEW PEW is offline
DIY Senior Member
I would try:
Radio Shack
Allied Electronics
Mouser
Jameco
Allied probably being your best bet.
  #3
Old 11-03-2009, 10:35 AM
Billy_Bob's Avatar
Billy_Bob Billy_Bob is online now
I should think a higher voltage rating like 370 volts would be ok so long as it was still .75 mfd.
So might have better luck searching for this by not including "330".
Also capacitors are abbreviated uF
So maybe search for
.75uF capacitor AC
or...
.75uF capacitor 370 AC
or 370 vac capacitors
(Might call and ask some of the places you find with the last search.)
  #4
Old 11-03-2009, 11:15 AM
jimbo's Avatar
jimbo jimbo is online now
Moderator and Plumber
Any electronic store such as the ones mentioned, or Frys, should have something. What is your application? If it is something like HVAC then a 370 VAC might be a better number. 1.414 X 240 = 339 volts!
But if the application calls for 370, it is available I am sure. In most applications, there is no downside to using a capactor with a higher max. voltage rating.
  #5
Old 11-03-2009, 12:39 PM
Thatguy Thatguy is online now
Whaddya' whaddya'?
Quote:
SNYD
Depending on your application, try Grainger.
Two 165v 1.5 uF in series will give you 0.75 uF @ 330vac [but you need some voltage sharing resistors] , or two 0.375 uF 330v in parallel will give you 0.75 uF @ 330v.
And what's your tolerance on the 0.75?
  #6
Old 11-03-2009, 09:09 PM
jadnashua's Avatar
jadnashua jadnashua is online now
Moderator, but not a Pro
The voltage rating on a capacitor is essentially its insulation rating...the point where it might short out by flashover or piercing the insulation layer. So, normally, using one with a higher voltage rating isn't an issue.
__________________
FWIW - Don't try to buy a phone from Nokia on-line
  #7
Old 11-03-2009, 09:31 PM
Cookie's Avatar
Cookie Cookie is offline
Reporter
http://ca.mouser.com/Search/Refine.a...VAC+capacitors
Do you have a parts number? or a company?
Check this out, maybe, http://ph.mouser.com/Passive-Compone...tors/_/N-5g7r/
http://itemlistings.****.com/sdcsrp?...52&xm&var=ngvi Do a search on e b a y I found one.
Type in,
MALLORY 72-86MFD 330 VAC PSU7230B 235-9528-04 CAPACITOR I would think, this would work, 9.50.
If I am wrong, please don't chop my head, just not enough information, but i hope this helps.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
