Terry Love's Plumbing & Remodel DIY forum
Go Back   Terry Love's Plumbing & Remodel DIY forum > HVAC Heating & Cooling
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 11-02-2009, 06:56 PM
bjferri bjferri is offline
Gov't Contractor / Defense
Question Boiler burner not igniting for 2nd zone, only 1st zone
The circulating pump is working for the 2nd zone, so why doesn't the flue damper open and burner ignite?
One thing may have contributed...the water was shut off for the 2nd zone while it/pump/thermostat was on. It wasn't until the pump was making a strange noise that I noticed but subsided when the water was turned back on and water flowing through the system. So I can hear the water circulating but the boiler doesn't ignite.
How do I troubleshoot this?
Thanks.
__________________
Brian
  #2
Old 11-03-2009, 09:17 AM
jadnashua's Avatar
jadnashua jadnashua is online now
Moderator, but not a Pro
Depending on how the system is configured, the boiler may not automatically come on with the circulator. It depends on the low set point. If the water is hot enough, the boiler only starts when it eventually cools off by being circulated through the heating looop(s). The low set point is often adjustable, so you could have something like 180/160, where the boiler would turn on to 180 then turn off and not turn back on again until it reached 160.
__________________
FWIW - Don't try to buy a phone from Nokia on-line
  #3
Old 11-03-2009, 04:49 PM
Jim,
It does appear to be working the way you explained. I think it may be working correctly but I was worried I burned the circulating pump motor out.
Question: Could I have reduced the performance of the pump? Maybe not pumping as fast as it was? After all, I did have the water shut off to that pump while it was running. It just seems like the 2nd zone radiators take longer now to heat up.
__________________
Brian
  #4
Old 11-03-2009, 08:56 PM
jadnashua's Avatar
The bearings in those pumps are lubricated with the water going through, so, if it was truly dry, at the minimum, you've probably shortened its life. Depends on how long it ran, and if there was any water in there at all.
__________________
  #5
Old 11-04-2009, 04:50 PM
thanks again...
__________________
Brian
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
all rights reserved, Love Plumbing & Remodel, 1992-2009
