Drip drip drip
Florida
there is probably an easy answer to this question. i just removed my bathroom vanity and faucet. And of course I completely turned off the water supply valves first.
Unfortunately one of the valves won't stop dripping. (I did leave the the braided connectors attached to the supply valves but i can't imagine that having anything to with it.) so i am guessing that i need to replace the valve?
I don't know the age of your stops and supplies but I would replace them all. They're not expensive, you'll have peace of mind but you may need a stop puller tool if your stops are on copper. Good luck. :)
There are new style stops that are 1/4 turn.
The stops are connected top copper. in fact are soldered. Will a stop puller tool get the valve off or do i need to call a plumber to blow torch them off?
If you decide to replace, you'll need to unsolder the existing valves unless the pipe is long enough to cut them off and still install a new valve. As noted, you may be able to just replace a washer, but the seat (the part it seals to) may be bad as well, and a new washer may not do much.
i appreciate all the replies. one last question. i unsoldered the valves and put on new compression valves. i was going to use teflon tape to connect the supply lines. should have i also have used teflon tape on the compression nut connection too?
NO TEFLON TAPE in this picture any where. NOT on the compression fitting, and NOT on any connection to the supply line. It will CAUSE a leak.
