clawfoot tub question
K2
Delridge Valley
www.draghead.com
please see the picture below, this is probably a stupid question but do I have to cut the pipes (A & B in the diagram) in order for it to line up with the drain and overflow holes? Or should it have been delivered with pipes that actually fit?
I bought the whole 'clawfoot tub package' and this is the hardware it came with...
Yes it needs to be cut. This can be done with a tubing cutter or hack saw.
John
Waste + Overflow
Make sure that you have your measurments right before you cut it, you will be a mad ***x if you cut it too short! :eek:
